Old Nov 11, 2010 | 05:45 AM
jonnyb's Avatar
jonnyb
Default Re: Map sensor-not working...HELP!!!
The SRT6 is a speed/density system and therefore uses a MAP sensor. Not sure about the NA Crossfires, but I think they may use MAF.
Back to original poster - sounds like you've got a really rotten stealership there. They did the work, they replaced the sensor, they need to figure out why the new one doesn't plug in. However, it seems like they are clueless, so let me try to give you something to guide them.
My guess is they replaced your MAP sensor with one from a NA Crossfire (or if as I said earlier MAF may be used on the NA Crossfire and they may have thrown one of those on your car). As I'm fairly new to these cars, this is only my guess based off of other factory boosted cars that I've dealt with. Most manufacturers used boosted/non-boosted harnesses and had special plugs for certain sensors (MAP being one of them). This was done so that mechanics (such as the ones you have just seemed to encounter) don't go and mess up and use the wrong parts on the boosted cars.
Putting a NA MAP (or MAF) on a supercharged application will yield disastrous results. While it's bad that you're running around without the MAP sensor plugged in, having an NA one plugged into your system could be much worse! Either way, you need to be careful if you are driving your car this way - the engine controller has no idea whether you are in boost and won't compensate with the correct amount of fuel. That will lead to a blown motor in no time!
You really need to back to the dealer and tell them you want the correct MAP sensor installed. Good luck.
