Old Nov 11, 2010 | 10:53 AM
cruzinquick's Avatar
cruzinquick
Default Re: Map sensor-not working...HELP!!!
Originally Posted by Dave Rockwell
All you mechanics out there.........HELP
After taking my SRT to Chrysler several times with major work being done the check engine light came on. Dealer said MAP sensor was changed but the wire harness connector would not plug into the sensor properly.......$2,ooo to get a whole new harness....
So I looked at the connector (very hard to get to) and I cannot see anything wrong......
The car works OK but not 100%
Cannot see spending the money for a new connector/harness.......but the MAP sensor is not being read by the ECU......Sounds like an easy fix but I can't see what to do...
ANY SUGGESTIONS
THANKS Dave
Try to find a reputable independent mercedes shop that will honor your warranty if you have one. If you don't have one then don't ever take your car to the dealer. Use mercedes forums to locate a good indy shop near you. They will understand what is wrong with your car once you tell them it's a SLK32.
