the trick to easy spark plugs swapping....
remove the single bolt for each motor mount and jack up one side of the motor at a time with a jack and block of wood, just dont forget to put the motor mount bolts back in
This is an AWESOME trick...will try it a s soon as my order for plugs & wires comes in from you....Which will be ordered tonight.....
thanks,
Jeff,
