Originally Posted by Goldwing
Before I'd let the knuckleheads touch it, suggest you clean off the oil near the valve covers and then gently tighten all the bolts. That did it with two of mine. If it continues leaking, then bring it in and have them replace the gaskets.
there aren't any gaskets....but, trying to tightened them down first is a good idea....I have the roadster's driver's side done, now the other side needs done...not a difficult project...you just need a good tube of sealer...AMG doesn't use gaskets...
