Car won't start! ... need help diagnosing the issue
Over the weekend my SRT initially had a issue of a really rough idle when I came to a stop light. I turned the car off at the light and re started and everything ran fine but a check engine light came on. The next day I go to autozone to try and get the code but as the ground was wet the employee would not go read the code.. he refers me elsewhere and I go try that and it closed already. So I go home and decide to disconnect the battery and reset the code. Had the battery disconnected for a half hour and I reattach everything and the car will not start. I went and bought a new battery as the car was still on stock and it had corrosion issues so why not get a new one. Hook it up and same problem it wont start. All the lights on the dash flicker when trying to ignite the motor as it it makes click noises. I had the CPS replaced a few weeks prior as that went bad. I am completely lost and cant think of what the issue is. Can anyone here give me some guidance on what I should look at before I get it sent off to get it looked at?
