Old Nov 14, 2010 | 09:01 PM
musicnsurf's Avatar
musicnsurf
Default Re: Car won't start!.. need help diagnosing the issue
Originally Posted by srtswizz
Over the weekend my SRT initially had a issue of a really rough idle when I came to a stop light. I turned the car off at the light and re started and everything ran fine but a check engine light came on. The next day I go to autozone to try and get the code but as the ground was wet the employee would not go read the code.. he refers me elsewhere and I go try that and it closed already. So I go home and decide to disconnect the battery and reset the code. Had the battery disconnected for a half hour and I reattach everything and the car will not start. I went and bought a new battery as the car was still on stock and it had corrosion issues so why not get a new one. Hook it up and same problem it wont start. All the lights on the dash flicker when trying to ignite the motor as it it makes click noises. I had the CPS replaced a few weeks prior as that went bad. I am completely lost and cant think of what the issue is. Can anyone here give me some guidance on what I should look at before I get it sent off to get it looked at?
new battery? proper (read high) cca? cable ends and battery terminals wire brush clean? these cars are unforgiving if the basics aren't checked first.
