Old Nov 15, 2010 | 09:52 AM
PNA's Avatar
PNA
Default Re: help transmission leak maybe?
Originally Posted by XfireBlake
BTW the NAG connector is just inches behind the bell housing, oh and one of mine broke while being removed and the tranny had to come out. It was free since still under warranty but the second one cost me $86 Neither lost a drop since!
Just took mine in to get the tranny connector installed. Part was $15. Fix time would have been about a half hour. Unfortunately for me, the tech had the same issue as others with the bolt / screw which holds the connector into the tranny -- it loosend but he wasn't able to extract it. The fix then goes to having to pull pan, break the connector to get it out an order the whole internal part for which the connector plugs into. Quote for that part was $1400!!!!!. I had them put back in the old one and am now looking for further guidance and extracting the bolt (I talked to the tech and he tried applying pressure and backing it out but it didn't work) and / or purchasing the part myseld and having them install it. ANY IDEAS ARE APPRECIATED?
