Old Nov 16, 2010 | 11:11 PM
onehundred80
Default Re: Car won't start!.. need help diagnosing the issue
Originally Posted by musicnsurf
depending on your location, 730 cca is on the lower side of an oem upgrade. personally, i would have gone with a napa 84 month (770 cca) or higher since these cars like their juice. i'm really glad that srtswizz was able to find an easy fix and got an appropriate battery in the process.
Batteries with a very high cca are not the best because of the high cca. They give a high amperage to start the car but the storage (amp hours) is much lower.
It's a trade off, you either have a battery that stores a lot of power or you have one that has a higher cca. It all depends on the number of plates in each cell. More plates equals higher cca, less plates equal more reserve capacity.
The OEM Varta battery had around 640cca, with a reserve capacity of 150 minutes. This was a good battery and more than adequate for the task.
My earlier post, lost in the past these days, explains this in more detail. Follow the sites at the bottom and you can learn more than you ever wanted or need to know about batteries.
Light weight batteries do not store much power, they cannot because there is no mass to store the power. The heavier the battery the more power it can store.
https://www.crossfireforum.org/forum...tml#post340783
