Re: Headlamp (bulb) failure
Sylvania and/or Phillips were the first two, which I replaced myself. The last one was put in by the mechanic I use since I took it in to check for an electrical problem that might be the cause. I know they used a high end bulb, but it's only lasted maybe three months. I'll be sure to check the fuse and connector when I replace it this go around. Thanks!
