Re: flashing wrench...
RESETTING THE FSS MAINTENANCE
INDICATOR
The FSS maintenance indicator can be reset to the total mileage
or total time in two ways:
Automatically when the odometer is reset to 0 within the
first 155 miles. (The FSS maintenance indicator is reset to the
values set at the factory).
Manually by driver by:
1. Hold the left rotary dial depressed.
2. Simultaneously move the ignition switch to the “RUN” position
3. Continue to hold the rotary dial down for 10 seconds.
After the audible tone 15,000 km (7,500 miles) appears on
the display. The remaining mileage is displayed again.
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and
hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
