Originally Posted by Lowell
My dealership service department claims that Chrysler tech support has NOT had such a complaint to date and hence can not suggest a “fix” for the issue of slow ignition.
Well so they should start! Every complaint once was the first. Silly a$$es!!
Lowell, sorry to read about your problem. I too drove several XFs and never had start delay.
There may be many things cause this: Fuel pump, bad spark plugs, ignition distributor, transformer coil, cam shaft sensor, crank axle sensor etc. Let the dealer do the search!
Good luck.
