Old Nov 23, 2010 | 12:09 PM
onehundred80
Default Re: Pulley Noise I Think? Help Me Please...
Originally Posted by HackZ
The pulley I was moving th the one directly above the crank pulley, I do not know what it is. I just put a wrench on one of the bolts and moved it up and down it did move a lot. I will take the belts off today and post back on here what I find.
What pulley do I move to get the belt off. Also what is the tension I want on the belt. Thank you all so much!
I assume you moved the belt tensioner, this is what puts tension on the belt. You do not have to do any adjustment as the tensioner does it automatically.
You can move the tensioner in the direction you are moving it now and you can insert a pin in it, if you know where the pin goes and lock the tensioner in place. You can then remove the belt.
Keep your fingers away from the belt and pulleys until the tensioner is locked in place.
See the service manual for all details.
https://www.crossfireforum.org/forum...tml#post111722
