Old Nov 24, 2010 | 05:34 AM
green-ghost's Avatar
green-ghost
Default Re: Dont' be Still my car
I think the car will crank over with the RCM issue but will not start sometimes.
There has been trouble cranking caused by bad connections at the battery, grounding and battery cables that are corroded, some times the corrosion cannot be seen.
I would take a stab at a new battery, if it is old and new cables. If the solenoid on the starter clicks when not turning over it could be a starter or solenoid issue.
There was a mention of a huge fuse that was not making good contact, that's in that black box near the battery I think.
True, the corrosion can form on the inside plates as well over time too.
I did what I thought was a good job fixing my rcm but ended up sending it to Tiged1 to get it done right...oh do the horn of all time mod too when you have it out
Pooly
