Originally Posted by dtinker
Any info on possibility of putting the beeter calipers on the NA rotors. I thinkI would have to change Rotor and caliper. I was just thinking of beter clamping power with some ceramic pads.
Dave
dtinker
There are probably some good MB calipers that will work with the n/a 300mm rotor. Most likely they will be on a C or CLK class cars. I haven't done the research for this. If you use the M/B part number of the stock rotor and cross reference it, you will find compatible MB's and can then check what type of calipers they used and probably find something nice and useable on ebay. I can check this if you send me the part number.
the SRT rotors are 330mm and fit right on a n/a. You can then go with CL500 or S500 class four piston calipers. Mine came from a 2002 CL500.
another option is C32 rotors and calipers. this can be expensive but CLK500 are the same exact caliper except they say Mercedes Benz on them instead of AMG. they are much less expensive used. This set up gives you a 345mm rotor.
