Old Nov 29, 2010 | 08:28 PM
  #56 (permalink)
32krazy!'s Avatar
32krazy!
Default Re: Engine flutter? Normal?
Originally Posted by Infinite
I wouldn't exactly classify the srt-6 as a high horsepower vehicle.. It has power but not lots of it
rudy would you take care of my lightwork?
that bearing is toast. dont drive the car until you get it fixed, the damage it can cause will be 3 times as costly. be aware if you have an extended warrenty they wont fix the bearing but replace the entire s/c! if not the bearing is 50$ from hpautowerks and can be done in 30 minutes if you have a press
lastly the idler pulley next to the s/c and below is junk. i would suggest you ask rob at needswings to to make you a c3 pulley saver kit. it will cure all the idler bearing failures you are going to experience. adds a bit of beltwrap also
