Old Nov 29, 2010 | 09:38 PM
CharlieO's Avatar
CharlieO
Default Re: 6-speed base model, Special Edition, or Limited?
Originally Posted by TiredRetired
Fog Lamps. Good ones too, 55W not the usual wimpy ones found on a lot of cars. Besides, it just looks right with them. A car at this level just does not look right without them. That, of course, is just my opinion.
Electrically operated seats. 6 way driver and 4 way passenger. A biggie for me as I am 6'2" and need to lower the seat all the way down.
Electrically heated leather seats. This one I thought I would never use as I will not be driving my roadster in the winter. However, the test drive with the top down and 47 degrees changed my opinion on that.
Tired
Thanks for your comments. I can tell you that I definitely can live without fog lamps. I have had them on several cars, and have never used them. Not much fog here. In addition, I've had to spend money to replace broken fog lamps that I never even turned on.
I would like electrically-operated seats, if they move back automatically when the door is opened to make entry/exit easier, and have a "memory" feature. Is this what is on the Limited? If not, the manual seats should be fine for me. I'm 5'8"" and don't have much difficulty getting into or out of my car.
I also have absolutely no need for heated seats. My wife uses the one on the passenger side of my Lincoln, often at the same time that I am cooling mine.
In my experience, the prices I am seeing on the base model and Special Editions with manual transmission are quite a bit lower than Limiteds with automatic. They're also a bit lower than Limited with stick.
