Re: Lighting system warning light
BODY VERIFICATION TEST
1.Turn the ignition off.
Disconnect all jumper wires and reconnect all previously disconnected
components and connectors.
Note: If the SKREEM or the PCM was replaced, refer to the service
information for proper programming procedures.
If the Body Control Module was replaced, turn the ignition on for 15 seconds
(to allow the new BCM to learn VIN) or engine may not start.
Program all RKE transmitters and other options as necessary.
With the DRB IIIT, erase all Diagnostic Trouble Codes (DTCs) from ALL
modules. Start the engine and allow it to run for 2 minutes. Operate all
functions of the system that caused the original complaint.
Ensure that all accessories are turned off and the battery is fully charged.
Turn the ignition off and wait 5 seconds. Turn the ignition on and using the
DRB IIIT, read DTCs from ALL modules.
Are any DTCs present or is the original complaint still present?
Are any DTCs present?
YES >> Repair is not complete, refer to appropriate symptom.
NO >> Repair is complete.
