Originally Posted by billybob
auto shifter will not move into reverse or park , starts in nuteral moves into drive
If you have an owners manual it tells you how to fix it.
What you do is...
There is a little push in door or flap at the base of the shifter plate. Can't miss it.
Put the multitool that should have come with the car in the hole, If you don't have the tool use a phillips screw driver and just push down it will release the shifter.
