the switch CAN be turned around
Ha gang I am not crazy, :? My window switch does work right.
I checked again and found you can pull the switch out and flip it around and put it back in. I posted 3 pictures showing the process.
1 lift the panal .
2 use both thumb nails or whaterver to push the tabs in toward the center then push the switch out from the top.
3 turn the switch around and push it back in.
4 reverse step 1.
Now if I could figure out how to get rid of this winter weather here in Ohio I could go out and drine my Xfire.
Richard Myers
Xenia, Ohio
#5599 Red 6 speed
