Re: Couple problems - just purchased - need advice!
Originally Posted by oojacoboo
sorry about the should have searched deal, I do know the drill. I didn't know what the problem was really, although, this does sound like it could be the issue. I appreciate all the help. I gotta make sure I can collect all the parts and tools for the job so I don't get stuck with a disassembled car and have to make a part run...
Before you get all worked up on the leaking oil issue you should check to find exactly where the oil is coming from. It could be the recirculating cover(s) these use a sealant , valve cover(s) these use a gasket, or the area around the base of the oil filling fitting.
Look before you leap, in some cases tightening the screws has fixed the leak. Just be careful not to exceed the torque settings or you will break a bolt.
See the Repair Manual, available on this site.
