Old Dec 8, 2010 | 12:52 PM
Goldwing's Avatar
Goldwing
Default Re: Bad Pulse Module = SuperCharger and Heated Seat Failure?
IC Pump problems should not have anything to do with heated seats. That's ridiculous. When the pump went on mine, I printed out a couple of the detailed threads from this forum and gave them to the dealer. It took them two test drives for the problem to manifest because they did not let the car heat up enough the first time.
Not sure what you mean by custom wheels and tires. Tires should not have any effect on TPMS. But the sensors are matched to each other and to the TPMS (from what I have read), so changing them or the rims could cause the sensor to be activated. I have no problems with my SRT6 but the icon has been lit for two years on my roadster and I check the TP regularly. I figure it's just a bad sensor and not worth fixing until I replace the tires and find out if Discount Tire can rebuild them.
