Originally Posted by TiredRetired
Interesting. Is the Cadillac unit close to the same wattage. Do they use a standard connector or would that need to be swapped out with the one from the failed unit? Thanx.
Tired
To be honest the Cadillac's were probably more wattage, but on low that wouldn't really matter. I seriously couldn't put them on high except just to jump start the heat. I never did see the specs on each, because I had no need. Mine were on an Eldorado and heated very well and very evenly, so like I said, even if I had to cut the plugs and wire them directly I would. Best heated seats I've ever seen. They're really only heating pads stuck to the foam and then covered with leather.
