Old Dec 10, 2010 | 09:08 PM
maxcichon's Avatar
maxcichon
Default Re: Hood Lift Support Question
Originally Posted by Germany
That button doesent work either. The rod is leaking at the lower end, so to prevent it oiling all over the car I took it out.
Are your sure?
Did you check under slk or Crossfire?
Under Crossfire it gives me $117.30
I think the "Full Up" position is a mechanical "click" type stop-not spring/hydraulic. It should at least hold it there. It's just when you press the button to release it you have to be careful! Think giant mousetrap!
But if you removed it, this is meaningless. Sorry!
