Old Jul 7, 2005 | 01:34 PM
Simon Templar's Avatar
Simon Templar
Default Re: Premium Gasoline?
Originally Posted by mjanowich
The octane level required by our engine has nothing to do with the horsepower, it's all about the compression ratio, which is about 10.5:1 If i remember correctly. I strongly suggest everyone follow the premium fuel requirement, unless you want to pay through the nose for a new catalytic converter or other various engine/exhaust system parts. I'm sure your warranty will be voided as well, since you didn't follow the fuel requirement.
Originally Posted by former NXMX5
an extra 10¢ a gallon for the right gas (an entire $1.60 per tank) is less expensive than the engine work that'll be required if and when anything does happen from using bad gas.
Just felt that both of these could bear repeating. In addition to the destruction and subsequent replacement of your catalytic, let us not forget such items as valves, valves seats, and the like. And...since they'll have to remove the head to do it anyway...why not hedge your bets and finish the rest of the overhaul? Just pocket change for you, perhaps?
Granted, this is a worst case scenario. But, where should we draw the line? And...how are you going to know just before you've reached it?
...sT
