Old Jul 8, 2005 | 01:03 PM
Heb80's Avatar
Heb80
Default Oil Filter Installation
Where does the biggest rubber O-ring on the oil filter go?
1) All the way to the top of the assembly, on the ridge just below the cap. This scenario would make it so that when the filter assembly is installed you can see the rubber between the plastic cap and the metal housing.
2) Or does it go at the top of the threads, below the ridge. This scenario would make it so that it is recessed down inside the housing when installed.
