Originally Posted by old man
do you find your speedo is off i was thinking about going with 295/30/19 i think is the same diameter as the 255/35/19
The diameter is not the controlling criteria in this case, old man, but the width of the tyre across the bead relative to the rim. It is recommended that the widest tyre to be SAFELY mounted on the stock OEM rim to be no more than 285 millimeters.
The 295's would be a stretch, so to speak, and the 30 aspect ratio would
really complicate matters.
