Re: Dyno - First Time - Great Results
Cool man, thanks for sharing! So this is your dyno after tune, right?
Edit: Never mind, I just reread your prior response - it was a pre-tune run.
Edit2: Just comparing your run and mine, the peak HP is very similiar, with yours starting higher, but what gets me is my torque figure. Your torque reading as well as others on the board that have posted up dyno charts are in the 330-350ft/lbs range when running a C3 or 178mm pulley.... I'm excluding the the 185mm pulley guys as it is apples to oranges.
Cheers,
KrzyFast
