Originally Posted by ZAHANMA
It is definitely slower than the N/A. It is because you're car is not JUST shutting off the Supercharger and operating the engine normally, but it is rather going into 'LIMP' mode where it restricts all processes in the engine to a point where it is still drivable but as far as possible from causing engine damage due to heat.
...a SRT with an out of commission I/C pump is slower than a prius. Seriously.
P.S. 7 month old thread.
I don't think the car is going into "limp" mode. Limp home mode doesn't allow you to shift out of second gear. When the IC pump goes, the computer simply disengages the SC. The FI engine has a lower compression ratio and 100 extra pounds. I think it may be this that makes it feel slower that the N/A.
