Old Dec 17, 2010 | 08:47 PM
corfire's Avatar
corfire
Default Re: Chirping Alarm Siren (lock/unlock)
I do not want wires spliced all over the place nor do I want a buzzer wire wrapped around relay pins. If I cannot just parallel the new chirping siren outside the cowl/under hood, then I will just go ahead and install it in the originals place.
I would not advise trying to connect two sirens on the same circuit. So, the replacement seems to be what you should and want to do. However, I have had the radio shack buzzer (tone mod) installed for almost three years without any problems with just solid wire wrapped to the relay pins, but they could be soldered. The mod can be removed in just a few minutes if one whats to restore the circuit to the original condition. It really is a simple inexpensive little mod.
