Old Dec 20, 2010 | 02:24 PM
mjgroves's Avatar
mjgroves
Default Re: WTB: Shims for the 1st gen (?) C3 pulley
Shims are actually made for a wide variety of uses and a lot of them can be purchased off the shelf.
Generally the ID or OD are important but the other diameter is often less so.
Let me know the ID and the OD and which one is important and I will look.
Custom shims require the tooling to make them and no one is going to make a set up for a few bucks.
Doc, since you are not parting with your shims, would you be so kind as to take the ID and OD measurements so onehundred can look/I can see if I can find any myself? Kinda desperate here.
EDIT: I'm curious... do the stock shims work? I am wondering if I can go to a junkyard and find a C32 (doubtful for SRT6) and grab some shims off off it.
-Matt
