Originally Posted by mjgroves
Doc, since you are not parting with your shims, would you be so kind as to take the ID and OD measurements so onehundred can look/I can see if I can find any myself? Kinda desperate here.
EDIT: I'm curious... do the stock shims work? I am wondering if I can go to a junkyard and find a C32 (doubtful for SRT6) and grab some shims off off it.
-Matt
The shims are the same as stock. My car came with 3 shims installed from the factory and they were identical to the 6 shims provided to me years ago from the first batch of Code 3 pulleys. That set up took all 9 shims to work.
I sold the pulley a few years later and ended up purchasing another pulley from HP Autowerks. It did not come with, nor require any shims. I had to actually remove the 3 stock shims for proper fit. Each of these cars will be slightly different, but the shims should be a fairly standard item. I would think they could be bought all the shelf with the proper measurments.
