Old Dec 20, 2010 | 08:11 PM
32krazy!'s Avatar
32krazy!
Default Re: WTB: Shims for the 1st gen (?) C3 pulley
mj is the pulley to close or to far away? i have a gen 1 pulley and needed 5 shims to get enough clearance to work. the newer versions didnt need any shims to get the cleaarnace. if you have the oem shims in place what i would do is remove all the shims and install the pulley torque to 20 nm NO MORE!! if theres clearance but no touching anywere your golden. if it touches anywere remove and add 1 shim then repeat. keep going till you find the sweet spot or run out of shims
remember the bolt is hollow 20 nm torque(14 ft/lbs ) if you torque it to 20 ft/lbs you will break the bolt. then you really have issues
hope it works for you
