Old Dec 20, 2010 | 09:27 PM
CharlieO's Avatar
CharlieO
Default Re: Is the top window problem on '05's only?
I still think that HEAT is the culprit more, but you DO present a valid theory. I always garage mine and almost never drive above about 35 with the windows down unles the top is down to - the virbration from the turbulance is kinda bad!
I suspect that the turbulence is part of the problem, and this, unfortunately, is another design issue with the Crossfire roadster. I have owned 11 convertibles, and none of them have had a problem with the rear window shaking as violently as the Crossfire's. Can anyone tell me if a windscreen reduces the turbulence when the top is up?
I have a tendency to ride with the windows up and the airconditioning on when I have the top up. If the weather is nice enough to open the windows, the top should be down! This might save me from having to repair or replace a top.
