Old Dec 22, 2010 | 06:37 PM
  #159 (permalink)
AlbertFattal's Avatar
AlbertFattal
Default Re: HID Install Lows and Fogs with Pictures
Originally Posted by rampntlion
Awesome. Thanks for the tip. Just installed a set of McCulloch 6000K HIDs using your directions. Each step worked exactly except for the mounting of the ballasts - my ballasts come with three holes integrated into them for mounting purposes so I couldn't use the already existing holes as you said you did. For now I used the provided M3 double-sided tape but will eventually mount them more securely. Does anybody have any suggestions as far as mounting the ballasts? The options I know of are: 1.) use stronger M3 style tape or silicone glue 2.) Use self-tapping screws [but I'd like to see if there is a way around drilling holes into the car, but if not - so be it].
I used existing bolts sticking out from the car. the braces/bracket that the ballast came with worked great, and the nut fit the existing bolts sticking out of the car stock to grag the brace of the ballasts
