Old Dec 23, 2010 | 01:45 PM
onehundred80
Default Re: Wheel Bearing Instructions
Originally Posted by caddyman3
Yeah Yeah...another suspected wheel bearing thread. I have been searching for the procedure on replacing the front wheel bearings but have found nothing. I'm trying to find torque values and if any special tools are needed. The car has a pulsating feel (not in the brake pedal)(also not a wobble). It varies with speed and gets worse in a hard left turn and better with a hard right. Anyone have the procedures for this?
Why not look in the Repair manual Section 2, page 24.
This is just to test them.
1. Remove the wheel and tire assembly.
2. Install a wheel bolt (1) on the opposite side from the brake rotor retaining bolt (5).
3. Press the brake pads back in the brake caliper making sure they do not come in contact with the brake rotor.
4. Remove the dust cap (2).
5. Loosen the hub nut bolt. Turn the hub nut (4) back until a slight end play is achieved.
6. Attach a dial indicator.
CAUTION: Do not turn the wheel hub while taking the measurement.
7. Adjust the wheel bearing end play by turning the hub nut (4) in stages while pushing and pulling the rotor firmly
back and forth. Adjust end play to 0.01–0.02mm.
8. Tighten the hub nut bolt to 11 N·m (8 ft. lbs.) and recheck the wheel bearing end play.
9. Remove the dial indicator.
10. Install the wheel hub dust cap (2).
11. Remove the wheel bolt from the rotor.
12. Install the front wheel and tire assembly.
Refer to Page 22-42.
