Old Dec 23, 2010 | 03:10 PM
Bill00's Avatar
Bill00
Default Re: Controller Anti-lock Brake
Originally Posted by Black03AR
Bill00,
The CAB is attached to the ABS Pump, and as such you will need to remove the ABS pump to change the CAB module. When doing this you should disconnect the battery. Once you have replaced the module and put everything back together again the light should go away by itself - well it did in my case. It wouldn't hurt to have an OBD II fault code reader/scanner around just in case.
Have you managed to source a new CAB module? There are usually some on Ebay, some are used and some are reconditioned.
I haven't tried to get a new one yet. The service manager said they are on national back order. I have seen used ones on ebay. I haven't decided if I'm going to go that route or not. I just don't like the idea of putting on a part from a fourty thousand mile car on a seven thousand mile car.
