Old Dec 25, 2010 | 05:52 PM
FTroopChief's Avatar
FTroopChief
Default Re: Just Another High School Dropout!
A lengthy description of Ogle's Patent including drawings, reference to 27 other system patents, and operation of his unit is written here:
Tom Ogle ~ Vapor Fuel System
Fuel Economy System for an Internal Combustion Engine
Tom Ogle (December 11, 1979)
Abstract ~
A fuel economy system for an internal combustion engine which, when installed in a motor vehicle, obviates the need for a conventional carburetor, fuel pump and gasoline tank. The system operates by using the engine vacuum to draw fuel vapors from a vapor tank through a vapor conduit to a vapor equalizer which is positioned directly over the intake manifold of the engine. The vapor tank is constructed of heavy duty steel or the like to withstand the large vacuum pressure and includes an air inlet valve coupled for control to the accelerator pedal. The vapor equalizer ensures distribution of the correct mixture of air and vapor to the cylinders of the engine for combustion, and also includes its own air inlet valve coupled for control to the accelerator pedal. The system utilizes vapor-retarding filters in the vapor conduit, vapor tank and vapor equalizer to deliver the correct vapor/air mixture for proper operation. The vapor tank and fuel contained therein are heated by running the engine coolant through a conduit within the tank. Due to the extremely lean fuel mixtures used by the present invention, gas mileage in excess of one hundred miles per gallon may be achieved.
Inventors: Ogle; Thomas H. W. W. P. (9028 Mt. Delano, El Paso, TX 79924)
Current U.S. Class: 123/522; 261/DIG83 ~ Intern'l Class: F02M 031/00
Field of Search: 123/133,34 A,122 E,134,136 48/180 R 261/144,145
I have no idea what it all means, the only questions being; does it work? and where is it?
John P
Last edited by FTroopChief; Dec 25, 2010 at 06:03 PM. Reason: delete duplicate post
