Old Dec 26, 2010 | 07:56 PM
bmorgan's Avatar
bmorgan
Default Re: My car only starts when it wants Help!!!
Originally Posted by bri3d
More info than "it doesn't start" would be extremely helpful.
Have you replaced your CAS? Do you notice a pattern with the car being harder to start/restart when it's hot? When the car runs, does it run well?
https://www.crossfireforum.org/forum...-no-start.html is definitely the first place I'd look, followed by the CAS if you haven't replaced it yet.
Won't be more than a few bucks to check both of these - the CAS is sub-$100, and RCM is free if you know how to solder at all. Both are very easy - the CAS is just a simple one-bolt remove and re-install and the RCM just slides out.
Ok, a CAS is new to me. What exactly is a CAS? Did you possibly mean a CPS (crankshaft position sensor)
