Thanks I'll« start hunting down grounds tomorrow...Anyone have an idea of how many I would be looking for.
Strange as it may sound a common cause of this is a poor ground, the contact is poor so the full voltage does not get across the connection, at other times the fulll voltage gets across.
One problem was found to be the battery cables themselves, corrosion had occured inside the insulation eating away the copper wire.
We had a similar problem on this forum last week, try and check out all the grounds, not just the obvious ones.
https://www.crossfireforum.org/forum...tml#post552550 (see post number seven, poor ground)
