Old Dec 28, 2010 | 11:01 PM
  #52 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: I did the ultimate mod for a crossfire (V8)
Originally Posted by 32krazy!
i had the privledge of seeing pauls car at the dragon gtg. from what i can see the fan will need to come out for any kind of pulley work. from the back and sides of the engine it looks as tight as the oem . i had to jack the motor to do mounts and the exhaust manis are a pain no matter what engine. plugs may be a bit tight but easier than a ls3 in a miata!!
The rear and sides of the engine are the same as OEM. When I installed my V8 I installed the engine with no accessories on it, not even a water pump, alternator, radiator, or fans. I wanted to make sure the car was serviceable, which it is. It is a tight fit but everything can be serviced just fine. There NO wasted space with the V8 conversion.
