Old Dec 31, 2010 | 10:18 PM
Moparrbust's Avatar
Moparrbust
Default Re: Tires sizes that will fit the body design of the XF
Originally Posted by Hambletonian
The 40's will suffice in the rear as long as you don't go too wide. You should be OK with the 275/40R19 and not rub fender wells, but how will it look? ... HMMM. But in any event, up front, any tyre taller and wider than 235/40R18 risks catastrophic conflict with the upper control arm nut.
As step one always, consider doing everyone a service and use the SEARCH function.
Regards.
I have personally run 315mm wide rear tires on the rear of my 6 without rubbing...............so there is no need to worry about 275's(unless you have some horrible offset aftermarket wheels).
