first center your steering wheel, then:
1. disconect the battery
2. remove two rear screws that hold on the air bag (allen wrench)
3. lift off air bag and unplug it.
4. remove the center large Allen bolt and the wheel will come right off. make sure your wheel is centered before removing.
Put new wheel on in the same position, and then revers the above to put back together. I had this done in about 15-20 minutes.
Excellent...thank you.
I guess because of the airbag I would never had imagined it would be that easy.
Thanks again.
