Thread: Jack pads
Old Jan 4, 2011 | 02:29 PM
BoilerUpXFire
Default Re: Jack pads
Originally Posted by hoody92
There is a plastic screw through the bottom of the pad. You might have to pry down on the pad while you unscrew it for the screw to get a bite.
This is someone who has never attempted to take these pads off the car.
When I was replacing my fender liners, I tried to access the pad to remove it. We ended up not needing to remove it, but in the process of spending 20 minutes trying, it is NOT as easy as removing one screw, it is 'built into' or sitting inside of the side skirt molding.
