Re: Adjustable Rear Camber Kit
If your lowered ..... if, if, if, if your lowered, you don't want the blue ones. Look at the stock arms, see that they're curved for clearance with the suspension? The replacement arms need to be slender where it passes the sway bar or, trust me, it will bang the sway bar unless you drive calmly and don't hit potholes, again, if your lowered more than 1-1/4 inches. The Kmac kit replaces the bushings on your stock camber arms.
Les
Reason: Don't have the blue ones anymore ...
