Old Jan 5, 2011 | 07:19 PM
onehundred80
Default Re: My code 3 install... the horror...
Originally Posted by mjgroves
I'm assuming the concerns were unwarranted if the pulleys run fine, though I understand the cause for concern!
Some additional info:
When I put my ear toward the top of the pulley, I don't hear much. But as soon as I put it up next to the front of the pulley (the bolt), the scraping noise becomes quite clear indeed. Bearing?
I guess I will have to install the stock pulley again and listen, then install the C3 and see if it's abnormal.
Will keep everyone posted.
From the memory of an old man.... I think the bearing for both pulleys is the same. If so a switch may be in order.
