Old Jan 6, 2011 | 08:40 AM
PNA's Avatar
PNA
Default Re: Drain hole leakage
Originally Posted by tom2112
Also it could be something nasty/dirty has gotten into the drain lines for the spoiler area. Check this pic out of the inside of the hatch with the interior panel off.
The arrows show where the water drains from the spoiler area down to the exit holes above the license plate. If something got into those lines, they just might need flushed.
Do the stains look dirty or rusty? If it's rust you're in for some bad news. If it's just dirt, you can probably just flush those lines with a couple gallons of water and some patience.
But if it were me, I would want to remove that hatch's interior panel and look inside to be sure you're not rusting out, and to be sure you know what's going on.
Just had the lower hatch panel off on mine to lube the spoiler mechanism. Good idea (and easy) to take it off, check out the interior / motor and see if water is getting in to the motor area. While you're in there, might as well put some lithium grease on the gears and struct mechanisms / rods.
If you haven't raised and looked under your spoiler / clean it when washing, it could be something has gotten up in there and continues to drain through the strut drain holes. It may just need cleaning and then take a long pipe cleaner and run them all the way through the drain holes to clean them out.
Hope it's something simple.
Good luck.
