Old Jan 6, 2011 | 02:09 PM
Sebastien_L's Avatar
Sebastien_L
Default Re: C240 airbox intake tube
Originally Posted by rcompart
The C240 airbox tubes don't go through the radiator support but rather connect to another tube right before it so I don't think that will be the perfect solution.
Thanks for the tip
A set of tubes from a Mercedes V8 like the 430's or 500's might be a better fit for you. You will have to trim the driver side a little for it to fit but if you take your time and only trim it back a little at a time on the bottom, it will still seal up fairly well and keep the hot engine bay air out of the intake.
So I need V8 intake tube, but what about those plastic support beside radiator?
I guess i'll just removed the OEM ones. Is the 430 or 500 benz have those?
