James, will the center rectangle rub out or is it into the paint? If it won't rub out, you will have to have your bumper repaired and painted.
If the center will rub clean, you can find flush plastic plugs to fit into the holes. Paint them in your color before installing. I have seen this done on yellow and are nearly invisible.
James
James,
Yes the "rectangle" rubs off and can be buffed away. I'll have to look for these clear plugs you mentioned. I believe the color code is in the VIN code, correct?
Thanks,
James
