Thread: problem advice
Old Jan 8, 2011 | 10:10 AM
KrzyFast's Avatar
KrzyFast
Default Re: problem advice
Hey guys, if his car is only cutting out momentarily (if I understand his original post correctly) could this not be the TC kicking in? If it was the pump then wouldn't the car be without power for a bit longer period of time (until it cools down)? When my pump started to go, I was without power for a couple of minutes at a time.
Just a thought..........
Good luck with getting your car sorted out. If your car does have the original pump, replacing it with a Johnston CM30 pump is a good idea. If the problem is not your factory pump now, it will be sooner rather than later.
Cheers,
KrzyFast
