Old Jan 9, 2011 | 08:30 PM
bmorgan's Avatar
bmorgan
Default Re: Removing front plastic on headlights
Using a heat gun would be nigh on impossible as one area would be getting cold as you worked on it.
The oven method does not appear to work from what I have read.
One member opened them up using an Xacto knife between the front and rear parts. Others have sawed them apart, If I had to do it I would favor the Xacto method.
Ever heard of using wedges as you heat each section.
